My set temperature on Avanti wine cooler is 53* but actual temp ( took with instant thermometer) is 75*. ( I removed all 54 bottles)
I've emptied it and turned it off. Since it has an auto defrost and knowing the inside temp, I'd hope there will be no water coming out, but is that a possibility? It's mighty heavy ay 115 pounds, so can't move.
Any thoughts on what can be done to get in working order?
