Fridge and freezer warm, food ruined. First thing I thought was evaporator coil Was frosted over so I immediately manually defrosted by door switch. Had an issue with this when got used last year. Been working great though. I ended up pulling cover off evap. coil in freezer and suprised by no frost, it was actually not even cold a bit, but fan was running. Condensor is running along with condenser fan. So everything seems to be working except evap. coil is not cooling! Freon?
