Discuss
Ice Maker Clicking Off
 in
Refrigerator & Freezer Repair
I suddenly started having an issue with my ice maker. When the both of the drain pumps turn on to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Clicking Off
  #1 (permalink)
Old 07-13-2016, 06:30 PM
Junior Member
mwalt1988 is on a distinguished road
Default Ice Maker Clicking Off
Model Number: 4689583   Brand: Kenmore   Age: 1 - 5 years
I suddenly started having an issue with my ice maker. When the both of the drain pumps turn on to remove the water from the ice maker, it clicks a couple of times and turns off. Both pumps work fine when run separately in the diagnostic mode. It's only when both of them are running. Any suggestions?
Related Models
Frigidaire 47-2151-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-00-02 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2151-23-02 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-02 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-00-05 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-02 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-04 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-23-05 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2351-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2351-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2451-00-01 Tap(v5) / 27 " Electric Dryer
Frigidaire 47-2451-00-03 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-00-04 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-23-01 Tap(v6) / 27 " Electric Dryer
Frigidaire 47-2451-23-03 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2451-23-04 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2551-00-03 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-23-03 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2551-23-04 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2707-00-01 Tap(v2)
Frigidaire 47-2707-23-01 Tap(v1)
Frigidaire 47-2751-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2751-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2828-00-01 Tap(v1) / Electric Dryer
Frigidaire 47-2828-00-03 Tap(v3) / Electric Dryer
Frigidaire 47-2828-00-04 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2828-23-01 Tap(v2) / Electric Dryer
Frigidaire 47-2828-23-02 Tap(v2) / Electric Dryer
Frigidaire 47-2828-23-03 Tap(v4) / Electric Dryer
Frigidaire 47-2828-23-04 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2848-00-01 Tap(v3) / Electric Dryer
Frigidaire 47-2848-00-02 Tap(v1) / Electric Dryer
Frigidaire 47-2848-00-03 Tap(v1) / Electric Dryer
Frigidaire 47-2848-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2848-23-01 Tap(v4) / Electric Dryer
Frigidaire 47-2848-23-03 Tap(v2) / Electric Dryer
Frigidaire 47-2848-23-04 Tap(v2) / 27 " Electric Dryer
Hoover 473.85920400 EXTR-W/FIX & ROT BRUSH,TEMPEST
Hoover 473.85930400 EXTR-W/FIX & ROT BRUSH,TEMPEST
General Electric 4742990 RADIANT MODULE
Jenn-Air 4755 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4760 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4770 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4775 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4790 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4800 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4800N RANGE- F/S STD DDRAFT ELE
Jenn-Air 4800S RANGE- F/S STD DDRAFT ELE
Frigidaire 4803A ELECTRIC RANGE
Frigidaire 48044 ELECTRIC RANGE
Frigidaire 480440A ELECTRIC RANGE
Frigidaire 480440D ELECTRIC RANGE
Frigidaire 480440E ELECTRIC RANGE
Frigidaire 480440F ELECTRIC RANGE
Frigidaire 480447A ELECTRIC RANGE
Frigidaire 480447D ELECTRIC RANGE
Frigidaire 480447E ELECTRIC RANGE
Frigidaire 480447F ELECTRIC RANGE
Frigidaire 4809A ELECTRIC RANGE
Frigidaire 4809B ELECTRIC RANGE
Frigidaire 4811 ELECTRIC RANGE
Frigidaire 4813-80B ELECTRIC RANGE
Frigidaire 4813A ELECTRIC RANGE
Frigidaire 4819A ELECTRIC RANGE
Frigidaire 4820A ELECTRIC RANGE
Frigidaire 4821-80A ELECTRIC RANGE
Frigidaire 4821A ELECTRIC RANGE
Frigidaire 4822A ELECTRIC RANGE
Frigidaire 4823A ELECTRIC RANGE
Frigidaire 4829A ELECTRIC RANGE
General Electric 4832990 RADIANT MODULE
Frigidaire 4833A ELECTRIC RANGE
Frigidaire 4839A ELECTRIC RANGE
Frigidaire 484240A ELECTRIC RANGE
General Electric 4842990 RADIANT MODULE
Frigidaire 48436 ELECTRIC RANGE
Frigidaire 484360A ELECTRIC RANGE
Frigidaire 484360B ELECTRIC RANGE
Frigidaire 484360D ELECTRIC RANGE
Frigidaire 484367A ELECTRIC RANGE
Frigidaire 484367B ELECTRIC RANGE
Frigidaire 484367D ELECTRIC RANGE
Frigidaire 4843A ELECTRIC RANGE
Frigidaire 484440A ELECTRIC RANGE
Frigidaire 484440C ELECTRIC RANGE
Frigidaire 484440D ELECTRIC RANGE
Frigidaire 484447C ELECTRIC RANGE
Frigidaire 484447D ELECTRIC RANGE
Frigidaire 484560A ELECTRIC RANGE
Frigidaire 484560B ELECTRIC RANGE
Frigidaire 484567A ELECTRIC RANGE
Frigidaire 484567B ELECTRIC RANGE
Frigidaire 484640A ELECTRIC RANGE
Frigidaire 4847-80B ELECTRIC RANGE
Frigidaire 4851A ELECTRIC RANGE
Frigidaire 4853 ELECTRIC RANGE
Frigidaire 4853A ELECTRIC RANGE
Jenn-Air 4855 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4860 RANGE- F/S STD DDRAFT ELE
Frigidaire 4863A ELECTRIC RANGE
Frigidaire 48654 ELECTRIC RANGE
Frigidaire 486540A ELECTRIC RANGE
Frigidaire 486540B ELECTRIC RANGE
Frigidaire 486540D ELECTRIC RANGE
Frigidaire 486547A ELECTRIC RANGE
Frigidaire 486547B ELECTRIC RANGE
Frigidaire 486547D ELECTRIC RANGE
Frigidaire 486640B ELECTRIC RANGE
Frigidaire 486640C ELECTRIC RANGE
Frigidaire 486640D ELECTRIC RANGE
Frigidaire 486640E ELECTRIC RANGE
Frigidaire 486647B ELECTRIC RANGE
Frigidaire 486647C ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker was clicking and then made no more ice. vmcompetello Refrigerator & Freezer Repair 0 09-24-2015 03:52 PM
HELP ice maker clicking won't make ice Coley78 Refrigerator & Freezer Repair 0 07-14-2012 08:43 PM
Ice Maker Clicking Noise triggerz71 Refrigerator & Freezer Repair 0 04-15-2011 03:14 PM
Ice maker CLICKING crwalkerasla Refrigerator & Freezer Repair 0 07-26-2010 09:00 AM
Ice maker clicking kchemers Refrigerator & Freezer Repair 1 02-06-2008 03:37 PM
