Greetings!
I have a 3 year old RF4287HARS refrigerator that recently stopped making ice. I have discovered that water is not filling the ice tray. As a test, I manually filled up the ice tray with a cup of water and it made/dispensed ice fine. Water dispenses fine from the front door. The freezer temperature is correct per the manual. Oh, the tub is not clogged or leaking.
Pressing the test button rotates the ice maker (fingers) three times.
I'm at a point where I have to purchase a control board or ice maker. Both are expensive. Any ideas on how to proceed?
Thanks in advance.
