So at first my freezer wasn't super cold. Ice cream was soft, etc. Then items in fridge like milk or fruit were freezing. Now everything in my freezer has thawed and the ice maker isn't working. I took the back panel off and the top right of the evaporator is frozen but the rest of the evaporator is not. I cleaned the ice off and it was back in minutes...any suggestions? Imgur: The most awesome images on the InternetI cleaned it all up, plugged it back in and put a small amount of water in the center of the freezer. It froze overnight, and the end of the evaporator is covered in ice again (probably looks worse than before, but before it was probably partially melted). However the ice pack on the door was nowhere near frozen... Any suggestions?
