Everything on fridge works other then the compressor. I replaced the Maine circuit board because I am only getting 2 volts dc to the inverter board at the compressor. The new board is sending out the same 2v dc. The other incoming voltage on the inverter is 120v. My compressor is reading 7ohms between all three windings. After powering the fridge up with my amp meter on the Main power supply I do not see any signs of the compressor running based on my amprages reading. Any help would be greatly appreciated. I'm leaning toward replacing the inverter board.
