Water on floor and drain pan was full . Emptied pan, checked seals on door, no leaks in water intake hose to ice maker. Water filter is removed and cap in place. Unit is cooling well: freezer and fridgerator. Making ice and dispensing cold water . Vents clear. Need help diagnosing water overflow problem.
