Refrigerator was working fine except the fan by the compressor was constantly turning on and off. Repairman said control board was bad but they have been discontinued and they can be repaired by several on line repair places. Since the frig was still working, I just let it go on for a few months but the other day the compressor stopped running. I found a place to repair the board but they question whether it is the board causing the problem. Could this be a failure of the inverter? Is there a was to check the inverter? I have a multi tester.
