Part number W10437847 is tube.. I need the tube with the end pieces that go into the connectors.. my tube is fine but the connector that's on the tube that goes into the quick disconnect busted.. and when I pulled up this part number it says it was replaced by another part number and this part doesn't have the same ends as mine it's just a tube...
