Hello,
First off thank you for your assistance. I have a leak coming from lower freezer door where waterline goes up to dispenser. Water only leaking from down there when water dispenser is used leading me to suspect it's a cracked waterline somewhere inside the freezer door section of waterline.
Is there a way to replace this and a part number? Any help is greatly appreciated!
Sorry, meant Kitchenaide not Frigidaire.
