The on/off lever you flip to turn the icemaker on or off doesn't want to stay in the down position to make ice. The icemaker will put water in the tray and then the lever goes up so when you wait long enough for the ice to make you can put the lever back down and it will empty the ice in the bucket and then fill back up with water then it will start it all back over again; the lever will raise up and stay up. The only way it's making ice is if you do it manually; let the water freeze then push the lever down and then it will dump the ice and it will re-fill with water again. Please some reply with a solution. Thanks
