robinleigh
#1 Posted : Tuesday, February 16, 2016 5:33:39 PM(UTC)
robinleigh
Hi, so for a few months ge side by side refridgerator ice maker dripped causing the ice drawer to become a bulk of ice. Annoying but still worked. Two weeks ago the top half of the freezer was super cold but not enough to freeze. Over past 2 weeks more and more wasn't frozen and now fridge is cold but not cold enough. I turned off the ice maker hoping that would solve the problem. Nope. Just took all the food out and the back panel - both the back of fridge and the coils are covered in what seems like snow. I have the fridge unplugged with a heater by it to try and thaw all the frost build up. FYI - coils are clean and the main board was replaced about 8 months ago bc of a fan issue.
applianceman
#2 Posted : Wednesday, February 17, 2016 6:53:12 AM(UTC)
applianceman
Make sure none of the water from the icemaker has made its way to the coils however since you described the ice as snow I assume you have a defrost issue. There are four things that can cause this and they are the defrost heater, defrost thermostat, evaporator thermistor and the main board. The heater is the most common followed by the thermistor. Check the heater first you can remove it and check it with an ohmmeter if it is open or very high ohms replace it (should be around 25-40 ohms).
This page will help
Refrigerator Defrost Problem Diagnostics
Scroll until you get to the section titled GE Electronic Refrigerator Defrost Problem
Your icemaker problem may be due to the water valve running too much water overflowing the icemaker sometimes the icemaker can cause this too. Sometimes water will leak over the edge (not due to overflowing) for various reasons. This can be solved using rtv under the cube separator on the edge of the cube form. Remove the cube separator and put a bead of rtv near where the water enters the icemaker. If the water comes in on the side of the icemaker put the rtv on the edge directly across from the water entrance.
