I have a Whirlpool SbS Frig (model #GD5SHAXKB02) with an Icemaker (model IM*S 106 2198597) that has quit working. I have reviewed some of your forum responses but I did not see an answer to my conditions. Here is what I know and have done.
1. Replaced Icemaker 2. Checked voltage between N&L terminals - 120vac 3. Jumped L&V, H&N, and T&H - nothing 4. Check water supply - clear 5. No lights from the optical controller 6. When the icemaker quit the tray overflowed and water ran down inside the freezer 7. After I removed the old icemaker and before I installed the new one we had a power outage for a couple of hours.
Ideas, recommendations??
Thanks Jim
