RonO37
#1 Posted : Sunday, November 29, 2015 11:55:36 AM(UTC)
RonO37
I have a Frigidaire upright freezer model GLFU1767FW2. The user interface board (LED display) on the door doesn't light up. Replaced the board and still nothing. Looked at the wires and see no wear. The compressor/fan/etc will run continuously and doesn't shut off.
Thanks for your time and help,
#2 Posted : Monday, November 30, 2015 1:50:20 AM(UTC)
Parts for Frigidaire GLFU1767FW2 Freezer - AppliancePartsPros.com
Sounds like the control board (item 54 in section 07) is bad.
I would check the freezer temperature.
Also remove the cover in the freezer and check the frost pattern on the evaporator coils.
It should be fairly even.
RonO37
#3 Posted : Monday, November 30, 2015 6:17:32 AM(UTC)
RonO37
Thanks for the quick response. That was my guess but wasn't sure. The cost was/is more than I want to spend without conformation. Will give it a try. I read that someone had a similar issue and they replaced both boards and still didn't work. Someone posted about two uncommon grounds that one may have been eliminated under a service call but this freezer was never serviced before.
Regards,
RonO'
Range control panel out stove top working (Oven Repair (including Ranges and Cooktops))
by nonlocal 1/3/2012 4:20:41 AM(UTC)
need to know how to get a control panel out of cabrio dryer (Dryer Repair)
by millbe 8/15/2011 2:23:12 PM(UTC)
Oven Control Panel Out (Oven Repair (including Ranges and Cooktops))
by teehippster 5/25/2011 9:03:31 PM(UTC)
