Kitchen Aide Side-by-Side [FONT="]Model: IN5500 Serial: 554136395 DOP: 7.17.2006 [/FONT] My Kitchen Aide Fridge (small side-by-side) has become noisy, and seems to be getting noisier daily.
The noise sounds like a fan, but I suppose it could also be a short-stroke compressor. Sometimes it is almost silent but much of the time it can be easily heard two rooms away. The kitchen is above the basement, and I can hear the noise when I'm down stairs. (I've owned this fridge since new and I'm familiar with its normal sounds.)
Both sides continue to maintain set temperature +/- 1F. (Freezer is 1.5F measured from first shelf below ice maker.)
A secondary (probably unrelated) problem: the freezer's digital temperature display is dark; fridge side is OK and accurate).
Thanks for your help,
Joe
[FONT="]
[/FONT]
