MY ice maker stopped working. I replaced the filter. Still not working. Ice maker not getting water. I ordered and rec'd the water valve P/N 242252702 - AP 5671757. I followed instructions to change it and I am having a water leak from my yellow tube connection. I attempted to pull out the tube to check it but was not able to do so. What do you suggest? Ed
Originally Posted by: Ed Bowe MY ice maker stopped working. I replaced the filter. Still not working. Ice maker not getting water. I ordered and rec'd the water valve P/N 242252702 - AP 5671757. I followed instructions to change it and I am having a water leak from my yellow tube connection. I attempted to pull out the tube to check it but was not able to do so. What do you suggest? Ed I had a water leak with my white tube connection but I was able to pull it out and recut the tube. When I reinserted it, it did not leak. Once the tubes are inserted, can they be pulled out to reinsert? I was unable to do this with the yellow tube??? ED
