I have a 3 months old GE french door fridge that gives me troubles from day one. The biggest complain is the noise. Original compressor was so loud that had to be replaced within a first month of use. After new compressor was put in the noise much quite, but there is constant water moving like or gurgling sound coming from the new compressor. Technician said it is normal, coolant moving through the coils, but I think that should not be happening all the time. Why i have not herd this before he replaced the compressor ? I am opening case with GE customer relation as technician says he can not do anything about this. What i read and herd compressor change is a quite big job 2-3 hours. The tech i had was done in less than 1 hour, is it possible that he cut corners and let something not completed ? Temperatures in freezer and fridge sections are OK, but this noise is like having dishwasher on all day long. Can someone help ? Please
