greythunder3
#1 Posted : Monday, October 26, 2015 10:42:34 AM(UTC)
greythunder3
I have a tri temp 5 gallon water dispenser that is not cooling the water, or the small fridge compartment below.
what i know:
-hot water dispenses just fine and measures 165F.
-room temp water also just fine and around 73F
-cold water is the same temp as room temp
-condenser on back of unit has surface temp on the top of 76F while on the bottom is 72F
-compressor runs, and will not shut off. after running for about 1/2 hour compressor surface temp is 137F and climbing.
-the typical "water drippng" noise can be heard from the compressor area.
any help where to start would be great! thanks!
#2 Posted : Tuesday, October 27, 2015 2:36:14 AM(UTC)
Sorry but it sounds like the unit is toast.
Since the compressor runs but you do not get any cooling, it is a sealed system problem.
This would be an expensive repair.
Probably a lot more than what the unit is worth.
Also trying to find a place that sells any internal parts would be very difficult, at least I cannot find one.
