I have a Whirlpool GD5NVAXSA01 that the fresh food side does not get cold enough. I cleaned the condenser, made sure it was defrosting. It cycles on and off but the fresh food section does not get cold enough before the compressor, condenser fan and evaporator fan cycles off. The freezer side gets to below 0 to plus about 3 degrees but I can't get the fresh food side below 45 to almost 50 degrees before it cycles. It is set all the way down to coldest and freezer control on 4. I am thinking control board inside food compartment or maybe thermistor. Also there is a delay for the evaporator fan to come on when the condensing section cycles in. Maybe 3 to 5 minutes.
Thanks, Ron
