Need to replace refrigerator thermostat. Removed conduit cover, damper cover, pulled thermostat censor off damper and removed screws from control panel which has slider controls, I am unable to remove panel to replace refrig thermostat. Would appreciate help and guidance how to remove control panel that I might replace refrig thermostat. Thanks~OldLearner
