tonydjd
#1 Posted : Monday, October 5, 2015 1:14:24 PM(UTC)
tonydjd
First thing all coils below clean. I unplugged let sit for 30 minutes plugged back in. Compressor cycles like it should.Defrost cycle on freezer works i.e heater. The damper door inside fridge works when I turn fridge compartment to Zero I watch the damper door close. When I turn dial to bring fridge up to temp door opens.
for some crazy reason the damper door does not close when fridge reaches temp.
Yes gasket on door of fridge is fine no issues:( :( :( :( :(
#2 Posted : Wednesday, October 7, 2015 1:27:00 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Frigidaire FRS23KF6CB0 Refrigerator - AppliancePartsPros.com
You know that the damper works but you do not know if the refrigerator thermostat is opening/closing.
You could remove it and hold an ice cube onto the end of it's capillary tube then with a meter check if the contacts open.
Fridge freezing food (Refrigerator & Freezer Repair)
by Lo444 10/21/2023 2:26:01 PM(UTC)
Samsung RS275ACRS side-by-side > coils in fridge freezing (Refrigerator & Freezer Repair)
by Guest 1/23/2022 10:34:43 AM(UTC)
fridge freezing up anf not cold (Refrigerator & Freezer Repair)
by mobetter 7/6/2021 8:51:05 PM(UTC)
Whirlpool SxS fridge freezing fresh food (Refrigerator & Freezer Repair)
by PeteClements 3/22/2015 6:15:47 AM(UTC)
Fridge freezing food, freezer coil iced up completely (Refrigerator & Freezer Repair)
by Hali Mark 7/4/2014 4:30:29 AM(UTC)
Fridge freezing (Refrigerator & Freezer Repair)
by Hector A. 1/11/2014 2:36:01 PM(UTC)
Woke up, Fridge freezing, freezer melting (Refrigerator & Freezer Repair)
by Beezer4me 12/28/2013 6:35:45 PM(UTC)
by Ricosuavey 12/12/2013 7:54:00 PM(UTC)
Refridge freezing food (Refrigerator & Freezer Repair)
by soiamsam 8/20/2013 6:51:06 AM(UTC)
Kenmore freezer on bottomm fridge freezing up and fridge not cooling (Refrigerator & Freezer Repair)
by homescool05@bellsouth.net 7/4/2013 3:05:12 PM(UTC)
GE fridge freezing refer compartment (Refrigerator & Freezer Repair)
by fishbreath 3/12/2013 10:45:25 AM(UTC)
Side-by-side fridge freezing foods on the side next to the freezer (Refrigerator & Freezer Repair)
by araratjan 1/7/2013 11:08:17 AM(UTC)
Freezer warm, fridge freezing (Refrigerator & Freezer Repair)
by Womlet 7/11/2012 7:24:06 PM(UTC)
Frigidaire side by side/ Fridge freezing everything (Refrigerator & Freezer Repair)
by jbarbero 6/27/2012 4:39:06 PM(UTC)
GE Arctica Fridge freezing food (Refrigerator & Freezer Repair)
by Tabreets 6/22/2012 11:24:18 AM(UTC)
