Frig is not cooling, freezer is sort of cool. Condenser gets hot(guess this is normal), fan motor does not kick on. I have 7.6 ohms across each combination of the terminals of the condenser. I read 118 volts into the Electronic Control Unit and read 218 and 219 volts at two of the pins at the condenser. I read 4 volts at the fan. Is the ECU bad? Is my condenser good? What do I need to check or replace? Thanks
