I replaced the ice auger motor and accidentally had it in backwards so that the motor was sticking out father than normal. When I was installing the front control panel it would not go in all the way because of the motor sticking out and I may have damaged the control board. Now, none of the buttons on the front panel work. The middle light for the filter is on and the ounces light is on. I am able to dispense Ice and Water using the paddles only. Any ideas...??? CaptainRex34 attached the following image(s):
