Hryarhucb
#1 Posted : Sunday, September 6, 2015 5:25:26 PM(UTC)
Hryarhucb
I have the above named & model # Refrigerator. Two door no frost 19 cu. ft. The refrigerator runs all the time. The top freezer compartment gets down to 12 degrees F and at the same time the lower fresh food compartment sometimes gets down to 32 degrees F. Then about two to three hours later the top freezer compartment goes up to 45 degrees F and at the same time the lower fresh food compartment goes up to 65 degrees F,
this process repeats itself over and over.
Does anyone have a clue as to what might be causing this to happen, and what the remedy might be?
Thanks,
Hryarhucb
jon.wilob
#2 Posted : Sunday, September 6, 2015 7:31:13 PM(UTC)
jon.wilob
That problem on my fridge was solved by replacing the sticking damper in the cold food section.
Hryarhucb
#3 Posted : Monday, September 7, 2015 12:48:39 PM(UTC)
Hryarhucb
Thanks, jon.wilob. I checked the damper it is ok and plenty of air is coming down to the fresh food compartment. However the ref. runs all the time and about every two- three hours it goes from 20 deg, in the freezer compartment to 60 degrees and same temp, of 60 degrees in fresh food comp. It repeats this cycle over & over.
Hryarhucb
Electrolux Refrigerator not getting cold (Refrigerator & Freezer Repair)
by jesus freak 3/30/2024 1:11:55 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
