Discuss
Freezer Hot on outside case & water under bottom
 in
Refrigerator & Freezer Repair
Inherited an upright freezer from my dad recently. Plugged it in & it runs, but not at cold enough temps.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer Hot on outside case & water under bottom
  #1 (permalink)
Old 08-17-2015, 12:11 PM
Junior Member
MikeB62 is on a distinguished road
Default Freezer Hot on outside case & water under bottom
Model Number: FFU17F5HWG   Brand: Frigidaire   Age: 1 - 5 years
Inherited an upright freezer from my dad recently. Plugged it in & it runs, but not at cold enough temps. Also the top & sides of unit are warm, almost hot to the touch. Pulled it out & went back to my old unit. Now have it in my garage to work on / fix.
Trouble shooting: unit runs almost continuously regardless of the setting, sides & top very warm continuously, found water underneath unit due to what I think is condensation from the unit running continuously & side heat.
Dad must have had a problem originally since he had an extra control unit (the one on the front door) with it. I swapped out that other control unit, freezer did not get down below freezing, sides of unit very hot, & the "high temp" light remained on the entire test period. Went back to the other control unit - temps went down to freezing levels, but the same old symptoms were back (warm / hot sides, condensation forming below unit.
Can you provide help / suggestions? Would like to use this freezer as its 15 years newer than my old one & a frost-free unit. From reading other posts, my non-expert guess is that the defrost element is somehow remaining on continuously while at the same time the compressor also must stay running to keep cold. Any help is appreciated. Thanks Mike
Related Models
Frigidaire FFU17F5HWG FREEZER
Frigidaire FFU17F5HWH FREEZER
Frigidaire FFU17F5HWJ FREEZER
Frigidaire FFU17F5HWK FREEZER
Frigidaire FFU17F5HWL FREEZER
Frigidaire FFU17F5HWM FRIGIDAIRE/FREEZER
Frigidaire FFU17F5HWN FRIGIDAIRE/FREEZER
Frigidaire FFU17F5HWP FREEZER
Frigidaire FFU17F9GW0 Frg(v0)
Frigidaire FFU17F9GW1 Frg(v1) / Freezer
Frigidaire FFU17F9GW2 Frg(v2) / Freezer
Frigidaire FFU17F9GW3 Frg(v0) / Freezer
Frigidaire FFU17F9GW4 Frigidaire/frzr
Frigidaire FFU17F9GW5 Frigidaire/freezer
Frigidaire FFU17F9HW0 Frg(v1) / Freezer
Frigidaire FFU17F9HW1 Frg(v0) / Freezer
Frigidaire FFU17F9HW2 Frg/freezer
Frigidaire FFU17F9HW3 Frzr - Frigidaire
Frigidaire FFU17FC3AW0 Frigidaire/freezer
Frigidaire FFU17FC4AW0 Frigidaire/freezer
Frigidaire FFU17FC4AW1 Frigidaire/freezer
Frigidaire FFU17FC4AW2 Frigidaire/freezer
Frigidaire FFU17FC4AW3 Frigidaire/freezer
Frigidaire FFU17FC4CW0 Frigidaire/freezer
Frigidaire FFU17FC4CW1 Frigidaire/freezer
Frigidaire FFU17FC4CW2 Frigidaire/freezer
Frigidaire FFU17FC4CW3 Frigidaire/freezer
Frigidaire FFU17FC5CW0 Frigidaire/freezer
Frigidaire FFU17FC5CW1 Frigidaire/freezer
Frigidaire FFU17FC5CW2 Frigidaire/freezer
Frigidaire FFU17FC5CW3 Frigidaire/freezer
Frigidaire FFU17FC5CW4 Frigidaire/freezer
Frigidaire FFU17FC5CW5 Frigidaire/freezer
Frigidaire FFU17FC5CW6 Frigidaire/freezer
Frigidaire FFU17FC5CW7 Frigidaire/freezer
Frigidaire FFU17FC5CW8 Frigidaire/freezer
Frigidaire FFU17FC8CW0 Frigidaire/freezer
Frigidaire FFU17FG4AW0 Frigidaire/freezer
Frigidaire FFU17FG4AW1 Frigidaire/freezer
Frigidaire FFU17FG4AW2 Frigidaire/frezer
Frigidaire FFU17FK0DW0 Frigidaire/freezer
Frigidaire FFU17FK0DW1 Frigidaire/freezer
Frigidaire FFU17FK0DW2 Frigidaire/freezer
Frigidaire FFU17FK0DW3 Frigidaire/freezer
Frigidaire FFU17FK0DW4 Frigidaire/freezer
Frigidaire FFU17FK0DW5 Frigidaire/freezer
Frigidaire FFU17FK0DW6 Frigidaire/freezer
Frigidaire FFU17FK1CW0 Frigidaire/freezer
Frigidaire FFU17FK1CW1 Frigidaire/freezer
Frigidaire FFU17G3AW0 Frigidaire/freezer
Frigidaire FFU17G3AW1 Frigidaire/freezer
Frigidaire FFU17G9HW0 Frg(v1) / Freezer
Frigidaire FFU17G9HW1 Frg(v0) / Freezer
Frigidaire FFU17G9HW2 Frigidaire/frzr
Frigidaire FFU17K1CW0 Frigidaire/freezer
Frigidaire FFU17K1CW1 Frigidaire/freezer
Frigidaire FFU17K1CW2 Frigidaire/freezer
Frigidaire FFU17M2AW1 Frg(v1) / Upright Freezer
Frigidaire FFU17M2AW2 Frg(v1) / Upright Freezer
Frigidaire FFU17M6AW1 Frg(v1) / Upright Freezer
Frigidaire FFU17M6AW2 Frg(v1) / Upright Freezer
Frigidaire FFU17M6AW3 Frg(v2) / Upright Freezer
Frigidaire FFU17M6AW4 Frg(v0) / Freezer
Frigidaire FFU17M7HWA FREEZER
Frigidaire FFU17M7HWB FREEZER
Frigidaire FFU17M7HWC FREEZER
Frigidaire FFU17M7HWD FREEZER
Frigidaire FFU17M7HWE FREEZER
Frigidaire FFU17M7HWF FREEZER
Frigidaire FFU17M7HWG FREEZER
Frigidaire FFU17M7HWH FREEZER
Frigidaire FFU17M7HWJ FREEZER
Frigidaire FFU17M7HWK FREEZER
Frigidaire FFU17M7HWL FREEZER
Frigidaire FFU17M8CW0 Frg(v0) / Freezer
Frigidaire FFU17M8CW1 Frg(v0) / Upright Freezer
Frigidaire FFU17M8GW0 Frg(v0) / Freezer
Maytag FFU180 FREEZER- VERTICAL
Frigidaire FFU2064DW0 Frigidaire/freezer
Frigidaire FFU2064DW1 Frigidaire/freezer
Frigidaire FFU2064DW10 FREEZER
Frigidaire FFU2064DW11 FREEZER
Frigidaire FFU2064DW2 Frigidaire/freezer
Frigidaire FFU2064DW3 Frigidaire/freezer
Frigidaire FFU2064DW4 Frigidaire/freezer
Frigidaire FFU2064DW5 Frigidaire/freezer
Frigidaire FFU2064DW6 Frigidaire/freezer
Frigidaire FFU2064DW7 Frigidaire/freezer
Frigidaire FFU2064DW8 Frigidaire/freezer
Frigidaire FFU2064DW9 FREEZER
Frigidaire FFU2065FW0 Frigidaire/freezer
Frigidaire FFU2065FW1 Frigidaire/freezer
Frigidaire FFU2065FW2 Frigidaire/freezer
Frigidaire FFU2065FW3 FREEZER
Frigidaire FFU2065FW4 FREEZER
Frigidaire FFU2065FW5 FREEZER
Frigidaire FFU2067FW0 Frigidaire/freezer
Frigidaire FFU2067FW1 FREEZER
Frigidaire FFU2067FW2 FREEZER
Frigidaire FFU2067FW3 FREEZER
Frigidaire FFU20F3AW0 Frigidaire/freezer
Frigidaire FFU20F3AW1 Frigidaire/freezer
Frigidaire FFU20F3AW2 Frigidaire/freezer
Frigidaire FFU20F3AW3 Frigidaire/freezer
Frigidaire FFU20F3AW4 Frigidaire/freezer
Frigidaire FFU20F6AW1 Frg(v1) / Upright Freezer
Frigidaire FFU20F6AW2 Frg(v2) / Upright Freezer
Frigidaire FFU20F6AW3 Frg(v1) / Upright Freezer
Frigidaire FFU20F6AW4 Frg(v1) / Upright Freezer
Frigidaire FFU20F6AW5 Frg/upright Freezer
Frigidaire FFU20F6BW1 Frg(v1) / Upright Freezer
Frigidaire FFU20F9CW0 Frg(v0) / Upright Freezer
Frigidaire FFU20F9CW1 Frg(v0) / Upright Freezer
Frigidaire FFU20F9CW2 Frg(v0) / Upright Freezer
Frigidaire FFU20F9CW3 Frg(v0) / Upright Freezer
Frigidaire FFU20F9FW0 Frg(v0) / Freezer
Frigidaire FFU20F9FW1 Frg(v0) / Freezer
Frigidaire FFU20F9GW0 Frg(v0) / Freezer
Frigidaire FFU20F9GW1 Frg(v1) / Freezer
Frigidaire FFU20F9GW2 Frg(v2) / Freezer
  #2 (permalink)
Old 08-18-2015, 11:25 AM
Junior Member
Default
Any help / suggestions from the Pro's?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water leaking out of freezer door, ice in bottom of freezer errolarena Refrigerator & Freezer Repair 3 11-18-2013 08:59 AM
Freezer water collecting @ bottom of Freezer JohnnyU Refrigerator & Freezer Repair 0 07-08-2012 07:49 AM
frost in freezer water under crisper bottom freezer fixtec90 Refrigerator & Freezer Repair 1 06-07-2011 06:42 PM
case of refrigerator and freezer hot schafer99 Refrigerator & Freezer Repair 1 09-10-2010 06:22 AM
Hot frame case between bottom drawer freezer and fridge rjaycochran1 Refrigerator & Freezer Repair 0 06-27-2009 06:56 PM
