Discuss
NO ICE KItchen Aid KSRP 25F Stainless Steel
 in
Refrigerator & Freezer Repair
Refridgerator KSRP25F, Side by Side, Stainless Steel Diagnostics light. Ice Maker Switch Position = Off Flapper = extended(Optics obstructed)/retracted(Optics
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » NO ICE KItchen Aid KSRP 25F Stainless Steel
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-18-2008, 08:32 PM
sologig sologig is offline
Junior Member
sologig is on a distinguished road
Default NO ICE KItchen Aid KSRP 25F Stainless Steel
Model Number: KSRP 25F   Brand: Kitchen Aid   Age: 1 - 5 years
Diagnostics light.
Flapper = extended(Optics obstructed)/retracted(Optics unobstructed)
LED: 2 blinks red/2 blinks red
Ice Maker Switch Position = ON
LED: 2 blinks red/Solid red
Water flows through door dispenser, with adequate pressure. Refridgerator is less than two years old. Until recently, ice maker worked, line became frozen. Line thawed, water flow restored, water flow is present, observed through door dispenser.
No ice but water runs through door service. Was able to defrost some of the black fill tube tonight, some ice out, only a litte water flowing through. I suspect line is still iced in some area. Will likely have to complete defrost.
Any other suggestions?
Thank you for your assistance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 08:51 PM
Junior Member
Default
Update:
It appears fill line has defrosted enough to flow water into cube form tray. Method of defrost was two fold. First tried a flexible copper strand wire heated with hair dryer, heat conducts through wire.. Second method, kitchen funnel with collection end into fill tube, flare end directs hair driyer heat into fill tube.
Probably just luck but, back in business.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchen aid washer mikeokonkowski Dishwasher Repair 5 01-30-2008 04:14 PM
Kitchen Aid Superbra bokeldol Oven Repair (including Ranges and Cooktops) 3 11-28-2007 11:17 AM
Frigidaire Stainless Steel Handle Broken cobra Microwave Repair 0 11-20-2007 12:56 PM
stainless plate inside tub bnablaze Dryer Repair 0 11-09-2007 10:46 AM
Kitchen Tap jtwestring General Talk 1 08-21-2007 02:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
