Problem started with water dripping from top of fridge. Cleaned freezer drain and drain tube. Still have water.Now fridge doesn't shut off. Freezer temp is 15 degrees. I noticed that the outside on the left side of freezer is real warm. Not sure if I need a temp control. Also cleaned the coils underneath and fan is working fine. I'm disabled from a stroke and not working so can't afford a repair man. Any help would be great. Thank you.
