It is a side by side unit. First there was a leakage of water under the fridge. I replaced the cracked storage cooling unit. then it happened again and again. this is the third unit I replaced. now the ice maker works, the water valve works and water reaches the line at the bottom of the freezer (when I disconnect the line there water comes out) but it does not reach the cup spout, when the switch is activated, you hear the normal click but no water shows up at the cup spout. When I kept the switch activated for a while, I heard the swooshing noise indicating another leakage at the cooler storage and water started to leak again. I took the dispensing unit off and checked the wiring and solenoid and switch, all is well there. what am I to do next please.
