Ice maker was working as normal then we started seeing water leaking from dispenser and had water inside fridge from where it had dripped down from the ice maker. Cleaned and emptied ice maker and it has not made ice since. Checked water pressure which is fine, have water being dispensed, bypassed filter and made sure ice maker is turned on and arm is not stuck...HELP!!
