Amana side by side with water and ice dispenser in door.
Problem: No water going to ice maker. Water dispenser working fine.
My Solution: I replaced the ice maker, the primary valve, and the secondary valve. Yes I'm a parts changer with limited troubleshooting skills so I just changed the parts. (True story I once threw all my dirty dishes away because I was too lazy to wash them and went to Target and bought all new ones.)
The fill tube is not frozen, I have great pressure going into primary valve, I can blow through the tube going from secondary valve to ice maker so there are no plugs.
I have swapped the connections on inlet valve and I get water at icemaker when I push the water dispenser so the valve is working correctly.
STILL NO WATER AT ICEMAKER!!
Please help me :confused: :confused:
