Discuss
relace capacitor/relay in refridge
 in
Refrigerator & Freezer Repair
I want to replace the capacitor and relay on the compressor--- the 3 in one that is being replaced has
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » relace capacitor/relay in refridge
  #1 (permalink)
Old 10-28-2009, 12:29 PM
hiway26 hiway26 is offline
Junior Member
hiway26 is on a distinguished road
Default relace capacitor/relay in refridge
Model Number: arb224rcw   Brand: Amana   Age: 5 - 10 years
I want to replace the capacitor and relay on the compressor--- the 3 in one that is being replaced has 120v line to it --- if I buy the seperate pieces, is there a lead attachment to tie the 120 line to...... looking at the pics in the puter does not show any leads..... thanks for advise.
Related Models
Amana ARB224RCW  Ref - Bottom Mounts
Amana ARB2257CB  Ref - Bottom Mounts
Amana ARB2257CC  Ref - Bottom Mounts
Amana ARB2257CSL  Ref - Bottom Mounts
Amana ARB2257CSR  Ref - Bottom Mounts
Amana ARB2257CW  Ref - Bottom Mounts
Amana ARB2259CB  Ref - Bottom Mounts
Amana ARB2259CC  Ref - Bottom Mounts
Amana ARB2259CS  Ref - Bottom Mounts
Amana ARB2259CW  Ref - Bottom Mounts
Amana ARB2517CB  Ref - Bottom Mounts
Amana ARB2517CC  Ref - Bottom Mounts
Amana ARB2517CSL  Ref - Bottom Mounts
Amana ARB2517CSR  Ref - Bottom Mounts
Amana ARB2517CW  Ref - Bottom Mounts
Amana ARB2557CB  Ref - Bottom Mounts
Amana ARB2557CC  Ref - Bottom Mounts
Amana ARB2557CSL  Ref - Bottom Mounts
Amana ARB2557CSR  Ref - Bottom Mounts
Amana ARB2557CW  Ref - Bottom Mounts
Amana ARB8057CB  Ref - Bottom Mounts
Amana ARB8057CC  Ref - Bottom Mounts
Amana ARB8057CSL  Ref - Bottom Mounts
Amana ARB8057CSR  Ref - Bottom Mounts
Amana ARB8057CW  Ref - Bottom Mounts
Amana ARB9058CB  Ref - Bottom Mounts
Amana ARB9058CS  Ref - Bottom Mounts
Amana ARB9058CW  Ref - Bottom Mounts
Amana ARB9059CS  Ref - Bottom Mounts
Amana ARC-1 Range - S/c S/i Ddraft Gas
Amana ARC-100 Range - S/c S/i Ddraft Gas
Amana ARC-100B Range - S/c S/i Ddraft Gas
Amana ARC-1B Range - S/c S/i Ddraft Gas
Amana ARC-2 Range - S/c S/i Ddraft Gas
Amana ARC-2B Range - S/c S/i Ddraft Gas
Amana ARC-506 Range - S/c S/i Ddraft Ele
Amana ARC100B Range - S/c S/i Ddraft Ele
Amana ARC100D Range - S/c S/i Ddraft Ele
Amana ARC1B Range - S/c S/i Ddraft Ele
Amana ARC502W Range - S/c S/i Ddraft Ele
Amana ARC505 Range - S/c F/s Ele
Amana ARC505B Range - S/c S/i Ddraft Ele
Amana ARC515 Range - S/c S/i Ddraft Ele
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700LL Range - S/c S/i Ddraft Ele
Amana ARC700WW Range - S/c S/i Ddraft Ele
Amana ARDS800E Range - S/c S/i Ddraft Ele
Amana ARDS800WW Range - S/c S/i Ddraft Ele
Amana ARDS801E Range - S/c S/i Ddraft Ele
Amana ARDS801WW Range - S/c S/i Ddraft Ele
Amana ARDS802E Range - S/c S/i Ddraft Ele
Amana ARDS802SS Range - S/c S/i Ddraft Ele
Amana ARDS802WW Range - S/c S/i Ddraft Ele
Amana ARE14 Misc / Accessory
Amana ARE640 Range - S/c S/i Ddraft Gas
Amana ARE650 Range - S/c S/i Ddraft Gas
Amana ARG3600L Range - S/i Std Gas
Amana ARG3600LL Range - S/c S/i Ddraft Gas
Amana ARG3600W Range - S/c S/i Ddraft Gas
Amana ARG3600WW Range - S/c S/i Ddraft Gas
Amana ARG3601L Range - S/c S/i Ddraft Gas
Amana ARG3601LL Range - S/c S/i Ddraft Gas
Amana ARG3601W Range - S/c S/i Ddraft Gas
Amana ARG3601WW Range - S/c S/i Ddraft Gas
Whirlpool ARG483WP01
Whirlpool ARG490
Whirlpool ARG4901
Amana ARG7102C Range - S/c S/i Ddraft Gas
Amana ARG7102L Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 10-29-2009, 05:07 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove the 3n 1 as soon as possible, particularily if the run capacitor was not installed. These units will destroy the start winding in the compressor!
Order the correct factory parts, AP4013414, start device and AP4074064, run capacitor. The original wires to the old start device where blue an white.
If the 3 n 1 was used because the compressor would not start with a new, original start device, you probably have a bad compressor.
__________________
  #3 (permalink)
Old 10-29-2009, 05:08 PM
Junior Member
Default continue the thought
Richappy
The 3-in-1 does contains a capacitor--- it is all together -- capacitor and relay.
I want to order the seperate units and install but the question is __ is there a lead to these items that will tie to the power line in the harness ??
looking at the photos of the pieces I cannot see a lead for this. I am probably overly concerned about nothing but not sure....
I did do a continuity test on the leads on the compressor and also the three leads against the clean metal of the compressor-- all checked good ...
Thanks for your help big guy..... joe
  #4 (permalink)
Old 10-30-2009, 04:43 AM
Senior Expert
APP Volunteer
Default
Turn the fridg on and measure the voltage to the blue and white wires going to the compressor, should be 115 volts.
__________________
  #5 (permalink)
Old 10-30-2009, 07:41 AM
Junior Member
Default richappy
voltage to compressor is 115 ---currently it is not hooked up because i need to install the relay and capacitor......
  #6 (permalink)
Old 10-30-2009, 10:19 AM
Senior Expert
APP Volunteer
Default
Very good, please keep us informed when you get the parts.
__________________
  #7 (permalink)
Old 11-04-2009, 04:37 PM
Junior Member
Default hiway26 has installed parts
Quote:
Richappy
The parts came today and I installed on the compressor--- results are: the compressor does come online but does not stay on --- runs about 4-6 seconds then cycles off. waits about 10 15 seconds then recycles again.....
I will search the database for this -- what do you think ? low freon? thanks for the assistance... hiway26
  #8 (permalink)
Old 11-04-2009, 04:52 PM
Junior Member
Default Parts installed --- compressor cycling
Richappy
did install the new parts on the compressor--- it did start ----stayed on for few seconds then cycled off... after 10-15 seconds recycled on-off again....
???? thanks for your assistance----
hiway26
  #9 (permalink)
Old 11-05-2009, 02:36 AM
Senior Expert
APP Volunteer
Default
If the syptoms are the same the first time this compressor failed, you probably have varnish buildup in the compressor. Sometimes a oil additive Supco 88 will fix this but takes a pro to put it in which is difficult for these fractional HP compressors, probably not worth fixing. Good fix would be new compressor, but rather pricey.
__________________
  #10 (permalink)
Old 11-08-2009, 08:19 PM
Junior Member
Default Richappy
Richappy --- This sounds like 'uh -oh' the string just run out, I guess.... more facts on this box---- brought to me because someone got rid of it-- initially the 3-n-1 was off the compressor and in several pieces, so after checking the nodes on the compressor and also to the body itself, all this looked good for the compressor, so me thinks 'well, just buy and install the seperate relay and such and maybe the box will go for a while(it is a beautiful box with bottom freezer) --- so what you are telling me is there is some problem in the compressor afterall........ I really thank you for the info.... hiway26
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Relay/Capacitor kbl88 Refrigerator & Freezer Repair 0 09-21-2009 09:18 AM
Connecting Capacitor To Overload/relay AUSGOD Refrigerator & Freezer Repair 1 08-25-2009 04:42 AM
Supco 3 N 1 (overload, capacitor, and start relay) bluefitness Refrigerator & Freezer Repair 6 10-29-2008 02:13 PM
Frig compressor/relay capacitor Mkendall Refrigerator & Freezer Repair 3 03-12-2008 02:31 PM
