Hi, the icemaker stopped working. I noticed that the sensor light ( across the freezer door) that shuts off the ice maker is not working. The switch is on - to turn the sesnor on. The water dispenser is working ok. Do you know what normally causes the sensor light to not work? I think there is a circuit board on both the sending and receving side of the sensor. Bob
