Our Maytag French Door fridge started making a fog horn sound when the ice maker cycled or you dispensed water from the door. Replaced filter, that didn't do it. Took filter out, that didn't do it. Based on research it looks like we need a new inlet valve. Was able to order no problem. Took both back panels off the fridge and there is no valve! Where the heck is it located????
Thank you!
