Discuss
Frigidaire Compact 3.1 manual defrost
 in
Refrigerator & Freezer Repair
I have a 3.1 cu. ft. compact refrigerator Freezer. Model LFPH31M6LM Serial KA11252616. My problem is that the freezer seems
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire Compact 3.1 manual defrost
  #1 (permalink)
Old 04-22-2015, 06:40 AM
Junior Member
Spit is on a distinguished road
Default Frigidaire Compact 3.1 manual defrost
Brand: Frigidaire   Age: 1 - 5 years
I have a 3.1 cu. ft. compact refrigerator Freezer. Model LFPH31M6LM Serial KA11252616. My problem is that the freezer seems to get quite cold..but the refrigerator section does not. I have the thermostat at it's max cold setting and it seems to run all the time, but the fridge does not seem to get cold like it should.
I have called Frigidaire cust service and they have nothing on the unit. I do have the paperwork that came with it the small wiring sketch that is with it shows only a compressor, overload, PTC, thermostat and light/lightswitch. No fan, no defrost system. I am a little confused as to why the fridge is not getting cold enough. I can but have not to this point attmepted to measure just how cold the freezer is and how cold the fridge is but the freezer is building up frost and I would guess the fridge is 50 degrees.
Anyone have any ideas
Spit
  #2 (permalink)
Old 08-12-2017, 08:47 AM
Junior Member
blocks is on a distinguished road
Default
Having the same problem. Changed thermostat, still not cooling in lower compartment (freezer is normal, -21C). Did some digging (literally through the insulation surrounding both compartments) and discovered the lower compartment has separate cooling lines rather than relying on the freezer to supply the cold. Apparently there is and issue in the lower line, just wondering what is it?
  #3 (permalink)
Junior Member
Default
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Auto-defrost only seems to work after manual defrost gtg932 Refrigerator & Freezer Repair 7 09-13-2014 11:27 PM
Frigidaire compact doesn't cool - clicks Nottheaveragejoe Refrigerator & Freezer Repair 7 03-28-2012 08:27 AM
Do a manual defrost Fastlanedan Refrigerator & Freezer Repair 1 11-05-2009 07:04 PM
oven temperature controller for old Frigidaire compact 30 oldgringo Oven Repair (including Ranges and Cooktops) 0 10-17-2009 09:40 AM
compact frigidaire capasitor ??? hdwguy Refrigerator & Freezer Repair 6 02-17-2008 04:21 AM
