Hi All,
My freezer is not cooling to the right temp. Currently, the top shelves and the ice maker are the warmest section of the Freezer. The bottom shelves seems to be cold enough to keep most food frozen. Typically, the ice maker does not freeze water, but occasionally will work only to heat up again causing the ice to melt and water to run through the water dispenser onto the floor.
Any help would be much appreciated.
Thanks!
Adam
