Joshua92
#1 Posted : Tuesday, October 27, 2009 10:56:44 AM(UTC)
Joshua92
OUr icemaker works fine at making ice and shutting off when the arm is raised. The problem is when the arm is down water freezes in the bottom of the ice storage tray. We need to use a knife to break it apart. I am guessing the inlet valve is not closing all the way and it needs to be cleaned/replaced. We have hard water. Two questions:
1. Can I remove the valve and soak it in CLR to break up any deposits that have built up without damaging the unit?
2. Could something else other than the inlet valve not closing completely be causing this problem?
Thanks,
Joshua
wondergd
#2 Posted : Friday, January 22, 2010 9:19:08 AM(UTC)
wondergd
:)What was the fix, I have the same troubles?
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Whirlpool Ice Maker Problem, Harness Questin (Refrigerator & Freezer Repair)
by uptwolait 1/31/2013 11:44:13 AM(UTC)
Whirlpool Ice Maker Problems (Refrigerator & Freezer Repair)
by TheB1GDude 7/15/2010 8:24:46 AM(UTC)
by ponyboy 11/10/2007 6:58:31 AM(UTC)
