Discuss
replacing defrost timer refrigerator
 in
Refrigerator & Freezer Repair
Your welcome.Leave it on 2 and you should be ok.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » replacing defrost timer refrigerator
  #11 (permalink)
Old 03-12-2015, 01:32 PM
Junior Member
dab147 is on a distinguished road
Default
  #12 (permalink)
Old 03-12-2015, 01:57 PM
Junior Member
bobvance is on a distinguished road
Default
OK
It ran the full DEFROST mode 30 mins and exited to COMPRESSOR mode.
Compressor and fans are on and it's cooling again.
But, again there is no power across any pins to the timer and it is not running.
So, what is causing the fridge not to send power to the timer and how is it ever going to get back to DEFROST mode??
Anyway, I'm going to replace the defrost thermostat next, but I don't see how it has anything to do with the power to the timer.
But it's only another $20 or so.
bv
  #13 (permalink)
Old 03-12-2015, 03:26 PM
Junior Member
Default
During non-Defrost, the Defrost Timer will run IF:
Cold Control is "closed" and Defrost Bi-Metal is "closed"
(Compressor is running, and Evaporator is cold)
  #14 (permalink)
Old 03-12-2015, 03:53 PM
Junior Member
Default
It will take time for the defrost thermostat to close after defrost as the defrost thermostat is rated at 18 degrees f.So the timer motor will not be turning.Let it run over night.
  #15 (permalink)
Old 03-12-2015, 04:03 PM
Junior Member
Default
Well the Cold Control *is* closed, because compressor & fan are on, evaporator is cold, its fan is running, & cold air is getting to the food comp.
The temps of both comps are maintaining properly.
BUT, you are saying that the bi-metal *does* affect whether the timer runs or not.
However, I don't know about whether the bi-metal is closing properly or not.
The freezer is reading between -4 at bottom and 16 F near top, so it *should* be closed if not defective. I will check it out.
bv
  #16 (permalink)
Old 03-12-2015, 04:16 PM
Junior Member
Default
Yes bi-metal affects whether timer runs.If the bi-metal does not close during cooling cycle and your temperature are what you say they are it should be closed.I guess when you said in the beginning of your post that it was not defrosting.Did you have frost on the evaporator from top to bottom ? Makes me think bad bi-metal.
  #17 (permalink)
Old 03-12-2015, 04:20 PM
Junior Member
Default
yes, all of the evaporator covered w frost totally full top-to bottom and at bottom plugged the air holes so that the food comp warmed up -- that's how I first noticed it: the wine wasn't as chilly as normal ;>)
bv
  #18 (permalink)
Old 03-12-2015, 04:27 PM
Junior Member
Default
Quote:
bv
Wine wasn,t chilly.Can,t have that.3 things cause heavy frost ,timer , heater and defrost thermostat.I would change that defrost thermostat.
  #19 (permalink)
Old 03-12-2015, 05:39 PM
Junior Member
Default
I snipped the thermostat out and it looks like it is open at all temps, so I am ordering a new one. Of course, the thermo was my initial thought, but during messing around I got the heater to actually come on twice, so thought it must be the timer.
Hopefully, new thermo will fix it and the new timer was unnecessary. But, I certainly learned a lot more about timers than I intended, so the money and time was well spent.
I will update when I get new thermostat.
bv
  #20 (permalink)
Old 03-13-2015, 09:20 AM
Junior Member
Default more drama
So, I tossed the thermostat into the freezer overnight and tested it again this morning.
Now, it's CLOSED at cold, so not sure what I saw yesterday, although I did shake it around a bit while I fooling with it last night.
Anyway, so I decided to FORCE the thermo circuit closed -- I just used a wire nut and shorted the ends where I had cut the thermo loose yesterday.
NO GO :[ -- timer (still in COMPRESSOR mode) not moving - motor not running (in the new timer it has a clear housing and you can actually see the motor.
So, I manually advanced timer to DEFROST mode.
Heater not heating up :[
BUT!
As I was looking at the wiring harness in the freezer, moving wires around I heard the telltale hiss of a short and it looked like it was coming from one of the heater element connectors. So, I wiggled the connector around and the heater came on !!
So, right now I'm just letting it finish the defrosting -- the timer runs about 30 mins.
When done, I'll OPEN up the thermo circuit and see what happens,
Will report back.
bv
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Defrost Timer puffedstuff Refrigerator & Freezer Repair 1 01-21-2015 01:09 AM
replacing defrost timer with new one attaches different. dcrockett Refrigerator & Freezer Repair 1 12-14-2011 05:55 PM
KENMORE 363 still not freezing after replacing defrost timer, heaters and thermostat carriagehouse Refrigerator & Freezer Repair 1 05-17-2010 05:39 AM
replacing defrost timer hinesw92 Refrigerator & Freezer Repair 0 10-22-2009 09:34 AM
problem replacing defrost timer DGDGBD Refrigerator & Freezer Repair 0 01-25-2009 11:34 AM
