The bottom drawer in my GE Monogram is warmer than the rest of the fridge - I ran diagnostics and the lower damper door does not open during the test cycle. Do I need to replace the damper unit or could there be something else causing the door to remain closed? I did run the thermistor test as well and all five passed.
