I have researched this problem all over the internet and have had multiple repair attempt to solve this issue without success. My ice maker performs normal for the first cycle, then no water is supplied to the ice maker as the fill tube freezes up. I have too manually reset the icemaker 4 times to get water to force its way out of the fill tube. After resetting the ice maker 4 times, the ice maker harvests ice and again the water line refreezes. This has been the problem since day one. Under warranty repairmen have replaced the motherboard, the entire door which houses the fill tube, the filter and the ice maker itself with successfully solving the problem. Also, I have checked the water pressure, which is good. One thing I have not replaced is the water valve, but no water is dripping after the tray fill.
Any suggestions?
