My Maytag French Door refrigerator model # MFI2568AEB had a problem with the control lights blinking and the ice door flapping. Replaced HIV Board part #12920710. Had to reprogram, code for my fridge was 1411, code was not accepted, put in a different code 0302 bingo! everything ok. Come to find out ice maker not working, but water dispenser is working. Purchased new ice maker #W10519364, still nothing. Ran T&H test nothing. Can't locate valves to check. Is it possible because of the change of codes HIV Board is not sending the correct signal to Ice maker ? Help !!!
