My ice maker is not getting power. The door switch is functional. There are four wires that plug into the ice maker inside the compartment. The hot wires are black and white. There is a plastic capsule about an 1-1/2" long on the black (hot) wire that looks like it could be a fuse. It is sealed.
Is it a fuse or should I look somewhere else?
