Frigidaire Side x side having damper issues. Came home one day to find the damper had broke and was making a very loud clicking noise as the motor was trying to open and close the damper. Ordered a new damper assembly...part number Electrolux 241600906. Got the new assembly installed and wired up. Now the new assembly is constantly running. The motor will not shut off and the damper is constantly, 24 hours a day, opening and closing. Will not hold damper at a constant spacing. What could be causing this?
Rank:: Advanced Member
Probably the control board. |
THIS FORUM IS DEAD!!!!!!! |
