FRS6LE4FW0
#1 Posted : Wednesday, January 28, 2015 6:49:30 AM(UTC)
FRS6LE4FW0
Freezer is not freezing. The fan runs in freezer. The compressor seems like it's on yet food is defrosting. It is cold in freezer.
#2 Posted : Thursday, January 29, 2015 12:43:03 AM(UTC)
Parts for Frigidaire FRS6LE4FW0 Refrigerator - AppliancePartsPros.com
I am assuming that the compressor runs all the time except when the unit goes through a defrost cycle.
Check that the condenser/compressor fan is also running.
Check that the condenser coils under the unit are clean.
Check that the vents on the kick plate and rear cover are clean.
If all OK.
Remove the cover in the freezer so you can inspect the evaporator coils.
If they are heavily iced/frosted over it is a defrost problem.
Could be the defrost heater, defrost thermostat of defrost board.
If there is frost on only one area of the coils (usually where the freon enters the coils) then it is a sealed system problem. This will be an expensive repair as you need a pro. In many cases it makes more sense to put those dollars towards a new unit.
jlupfer
#3 Posted : Wednesday, March 4, 2015 2:20:53 AM(UTC)
jlupfer
I am experiencing what sounds like a similar problem in my model. The fridge area is keeping food cold as normal, but the freezer is cold but not frozen. Fan is running.
Samsung RM255LASH Freezer Not Freezing (Refrigerator & Freezer Repair)
by crbishop74 2/14/2022 6:45:02 AM(UTC)
GX2FHDXVB00 whirlpool refrigerator freezer not freezing (Refrigerator & Freezer Repair)
by Nwhe54 12/21/2020 8:30:23 AM(UTC)
Viking Freezer not freezing but fridge is cool (Refrigerator & Freezer Repair)
by BgBrd 6/25/2020 11:41:34 AM(UTC)
Kenmore Elite freezer not freezing, but it is? (Refrigerator & Freezer Repair)
by colbran 4/24/2020 6:53:03 AM(UTC)
GE Profile French door - freezer not freezing (but fridge is!) (Refrigerator & Freezer Repair)
by annenap 2/26/2020 6:01:53 PM(UTC)
LG fridge LFC23760ST freezer not freezing, now fridge not cooling (Refrigerator & Freezer Repair)
by blairm 1/20/2019 1:40:44 AM(UTC)
Freezer not freezing after power outage (Refrigerator & Freezer Repair)
by otis732 10/8/2018 9:31:08 AM(UTC)
Freezer not freezing consistently (Refrigerator & Freezer Repair)
by mgatch 11/7/2016 2:02:58 PM(UTC)
by tatadude 10/9/2016 2:02:29 PM(UTC)
freezer not freezing /warm fridge.. help! (Refrigerator & Freezer Repair)
by Chickadee 10/8/2016 8:06:02 AM(UTC)
Magic Chef freezer not freezing. (Refrigerator & Freezer Repair)
by DavidESny 9/5/2016 7:07:37 PM(UTC)
Freezer not freezing (Refrigerator & Freezer Repair)
by tlbrown 10/28/2015 7:19:16 PM(UTC)
whirlpool bottem freezer not freezing (Refrigerator & Freezer Repair)
by samknopf 4/20/2015 6:33:10 PM(UTC)
Maytag upright freezer not freezing on top shelf (Refrigerator & Freezer Repair)
by Janis50 4/19/2015 9:03:49 AM(UTC)
Freezer not freezing & fridge is not really cold either. (Refrigerator & Freezer Repair)
by kimybrown 12/3/2014 8:25:15 AM(UTC)
