Icemaker looks good except no water filling.
Rubber fill line does not feel to be frozen inside. Water flow to water on front of refrigerator is strong. Resistance on Multimeter for Water valve on Freezer side = 250. Water side = 350. Can blow through freezer line at valve. Stuck paperclip in holes (w/electrical tape) on control panel - nothing happens.
Replace Water Valves or Ice Maker unit?? Thanks! Scott:D
