DiverDirk
#1 Posted : Tuesday, January 20, 2015 6:28:30 AM(UTC)
DiverDirk
Hello-
I have an 8 year old (2008) Kitchen Aid Wine Cooler KUWS24RSBS-01 that was making a slight noise for the last several days and then stopped running all together. It was cooling at 42 degrees (top and bottom) and then stopped running and displayed 74 degrees. I pulled off the back plate and found lots of dust in the starting fan, coils and surrounding areas; however, I checked the voltage for the starter and it is getting amps. I don't know if the starting fan and components have gone bad or the compressor and parts? Any suggestions would be appreciated?
Thanks -
#2 Posted : Tuesday, January 20, 2015 8:45:11 AM(UTC)
Here are your parts. You were missing the last two numbers in the model number so it is for a 01 unit.
Parts for KitchenAid KUWS24RSBS01 Wine Cooler - AppliancePartsPros.com
[COLOR="Blue"]I checked the voltage for the starter and it is getting amps. [/COLOR]
I think the above may just be a terminology problem re: you mean volts not amps.
[COLOR="Blue"]
I don't know if the starting fan and components have gone bad or the compressor and parts?[/COLOR]
The above is confusing as I do not know what you are calling a starting fan.
Perhaps the following will help.
Is the compressor running?
You can usually hear it but should also be able to feel it vibrating.
Is the condenser/compressor fan running?
If yes then the compressor should be running as they are wired in parallel.
So if it is on then the problem could be with the start device or the compressor itself.
Is the inside fan running?
It should also be on whenever the compressor and it's fan are on.
If neither fan and the compressor are not running then the problem could be with the defrost timer or the temperature control system.
Try turning the defrost timer cam (it only turns in one direction). If the unit fires up replace the defrost timer.
DiverDirk
#3 Posted : Tuesday, January 20, 2015 11:57:49 AM(UTC)
DiverDirk
Good Evening Denman -
I apologize; I meant volts and not amps…my mistake. The condenser/compressor fan is not running at this time and the 'fan motor', not the starting fan (as I referred) is not turning on as well. Actually, there are no fans running at this time. It's very quiet at the moment! I took the defrost timer cam apart and it does turn. What do you suggest next...
Please inform…thanks again for your assistance.
#4 Posted : Tuesday, January 20, 2015 11:56:09 PM(UTC)
Below is a link to a manual.
It is too big to download to this site so I have had to use a third party site.
Un-click the Use Our Download Manager button and then use the grey button to download it, otherwise the site may put software onto your computer that you do not want.
Download KUWS24 Wine Cooler.pdf
[COLOR="Blue"]
I apologize; I meant volts and not amps…my mistake.[/COLOR]
Not a problem.
Could you tell me how many volts and where you were measuring using the wiring diagram on page 7-1 in the manual for reference.
Did you try just turning the cam?
There are two reasons why the defrost heater could cause a problem.
1. the the cam is not turning.
2. the contacts are not closing.
I am assuming that the interior light works.
If not check the wall receptacle for power.
Now there are two top of the list things that can cause the fans and compressor to not run.
1. The main control thermostat contacts are not closing.
Unplug the unit and one wire at the thermostat and check across it with your meter. It should read 0 ohms. If not it needs replacing.
2. The defrost timer contacts (1 to 4 are not closing when in cool mode).
Same type of check as as above but you have to rotate the cam through 360 degrees just to be sure you are not in a defrost mode when you check it.
FYI: the defrost timer motor gets power through the defrost heater and it's thermal fuse when in a cool mode. It also uses this circuit path when in defrost mode but only advances after the ice has melted off the evaporator coils and the defrost thermostat has opened.
DiverDirk
#5 Posted : Wednesday, January 21, 2015 10:17:00 AM(UTC)
DiverDirk
Good Afternoon Denman -
I appreciate your assistance. Yes, I could turn the defrost timer prior to taking it apart. I opened it to see if the contacts were touching throughout the turn cycle and they are.
And yes, the interior light works and both temperature gauges read 74 degrees when plugged in.
I did unplug the unit and have checked the main control thermostat and it does read 0 ohms.
Any other suggestions would be greatly appreciated.
#6 Posted : Wednesday, January 21, 2015 11:47:56 AM(UTC)
[COLOR="Blue"] I opened it to see if the contacts were touching throughout the turn cycle and they are.[/COLOR]
Not sure if I am interpreting the above correctly but if one set of contacts stayed shut during a full rotation there is a problem.
One rotation is 24 hours.
So contacts 1 to 4 should be shut for 23.5 hours (cool time).
Contacts 1 to 2 shut for half an hour (defrost time).
The above are approximations as I do not have the actual timer specs.
Note that the 24 hours is compressor run time hours.
DiverDirk
#7 Posted : Wednesday, January 21, 2015 12:48:53 PM(UTC)
DiverDirk
I did see the contacts apart for the majority of the turning and then it made contact for a brief moment. You are correct.
Do you believe it could be something else?
Thanks again -
#8 Posted : Wednesday, January 21, 2015 1:06:27 PM(UTC)
[COLOR="Blue"]Do you believe it could be something else?[/COLOR]
It could be just a bad wire but I cannot really say.
Unplug the unit.
Set your meter to it's most sensitive resistance mode/scale.
Short the meter leads together so you know if there is a zero offset in the meter.
Place one meter lead on the A prong of the power cord and leave it there.
Now measure to the brown side of the thermostat. It should be 0 ohms.
Measure to the yellow side of the thermostat. It should be 0 ohms.
Measure to the yellow (contact 1) on the defrost timer. It should be 0 ohms.
Measure to the gray (contact 4) on the defrost timer. It should be 0 ohms.
If all are OK problem is likely on the white side of then wiring.
DiverDirk
#9 Posted : Saturday, February 7, 2015 9:40:17 AM(UTC)
DiverDirk
I just wanted to thank you for your time, energies and assistance in locating and diagnosing my problem. You were exactly right in that it was the Defrost Timer and I have replaced that $67 dollar part and the wine cooler is working like new.
Again, I thank you for your time and expertise in this area. May you have good karma this year...
