Discuss
Freezer & Fridge not cold - coils cold, evap fan works but not running
 in
Refrigerator & Freezer Repair
Hi. I have a side by side 2004 Frigidaire fridge that I am hoping to fix with some guidance. I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer & Fridge not cold - coils cold, evap fan works but not running
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-06-2015, 10:51 AM
Junior Member
bootpdx is on a distinguished road
Default Freezer & Fridge not cold - coils cold, evap fan works but not running
Model Number: FRS26rlec   Brand: Frigidaire   Age: More than 10 years
Hi. I have a side by side 2004 Frigidaire fridge that I am hoping to fix with some guidance. I returned from a 10 day vacation to find the top of the freezer compartment warm with thawed items. The fridge wasn't making the usual sounds although lights were working.
I removed the back panel to find snowy frost on the top of the evap coil assembly, but not enough to block the evap fan. The evap fan is not turning on, but I have bench tested it and it runs. Compressor is running - I also tested that and got the appropriate ohm reading. Also tested the starter relay and got resistance. The compressor fan runs as well.
The evap coil assembly does get cold when the fridge is plugged in, so I have chalked the problem up to the fact that the evap fan isn't distributing the air.
I think the fan is powered through the thermostat sensor (clipped to the evap coil) I tested it and didn't get any resistance, so I have ordered a new one. I hope that once installed, the evap fan will run and the fridge will be fixed. If it still doesn't work after this, then my next guess is to check the defrost board.
Anyone else have other ideas of what could be causing this? Trying to avoid spending $1000 on a new fridge.
THANK YOU
Related Models
Frigidaire FRS26RLECS0 Frigidaire/refrigerator
Frigidaire FRS26RLECS1 Frigidaire/refrigerator
Frigidaire FRS26RLECS2 Frigidaire/refrigerator
Frigidaire FRS26RLECS3 Frigidaire/refrigerator
Frigidaire FRS26RLECS4 Frigidaire/refrigerator
Frigidaire FRS26RLECS6 Frigidaire/refrigerator
Frigidaire FRS26RLECS7 Frigidaire/refrigerator
Frigidaire FRS26RLECS8 Frigidaire/refrigerator
Frigidaire FRS26RLECS9 Frigidaire/refrigerator
Frigidaire FRS26RLECSA Frigidaire/refrigerator
Frigidaire FRS26RLECSB Frigidaire/refrigerator
Frigidaire FRS26RLECSC Frigidaire/refrigerator
Frigidaire FRS26RLECSE Frigidaire/refrigerator
Frigidaire FRS26RLECSF Frigidaire/refrigerator
Frigidaire FRS26RLECSG Frigidaire/refrigerator
Frigidaire FRS26RLECSH Frigidaire/refrigerator
Frigidaire FRS26RLECSN Frigidaire/refrigerator
Frigidaire FRS26RLECSP Frigidaire/refrigertor
Frigidaire FRS26RLECSR Frigidaire/refrigerator
Frigidaire FRS26RLECSS Frigidaire/refrigerator
Frigidaire FRS26RLECST Frigidaire/refrigerator
Frigidaire FRS26SM4AW0 Frigidaire/refrigerator
Frigidaire FRS26SM4AW2 Frigidaire/refrigerator
Frigidaire FRS26SM4AW3 Frigidaire/refrigerator
Frigidaire FRS26TS6DW1 Frigidaire/refrigerator
Frigidaire FRS26TS6DW2 Frigidaire/refrigerator
Frigidaire FRS26TS6DW3 Frigidaire/refrigerator
Frigidaire FRS26TS6DW5 Frigidaire/refrigerator
Frigidaire FRS26TS7DB0 Frigidaire/refrigerator
Frigidaire FRS26TS7DB1 Frigidaire/refrigerator
Frigidaire FRS26TS7DB2 Frigidaire/refrigerator
Frigidaire FRS26TS7DB3 Frigidaire/refrigerator
Frigidaire FRS26TS7DB5 Frigidaire/refrigerator
Frigidaire FRS26TS7DW0 Frigidaire/refrigerator
Frigidaire FRS26TS7DW1 Frigidaire/refrigerator
Frigidaire FRS26TS7DW2 Frigidaire/refrigerator
Frigidaire FRS26TS7DW3 Frigidaire/refrigerator
Frigidaire FRS26TS7DW5 Frigidaire/refrigerator
Frigidaire FRS26W2AQ1 Frigidaire/refrigerator
Frigidaire FRS26W2AQ2 Frigidaire/refrigerator
Frigidaire FRS26W2AQ3 Frigidaire/refrigerator
Frigidaire FRS26W2AQ4 Frigidaire/refrigerator
Frigidaire FRS26W2AQ5 Frigidaire/refrigerator
Frigidaire FRS26W2AQ6 Frigidaire/refrigerator
Frigidaire FRS26W2AQ7 Frigidaire/refrigerator
Frigidaire FRS26W2AQ8 Frigidaire/refrigerator
Frigidaire FRS26W2AQ9 Frigidaire/refrigerator
Frigidaire FRS26W2AQA Frigidaire/refrigerator
Frigidaire FRS26W2AQB Frigidaire/refrigerator
Frigidaire FRS26W2AQC Frigidaire/refrigerator
Frigidaire FRS26W2AQD Frigidaire/refrigerator
Frigidaire FRS26W2AQE Frigidaire/refrigerator
Frigidaire FRS26W2AW1 Frigidaire/refrigerator
Frigidaire FRS26W2AW2 Frigidaire/refrigerator
Frigidaire FRS26W2AW3 Frigidaire/refrigerator
Frigidaire FRS26W2AW4 Frigidaire/refrigerator
Frigidaire FRS26W2AW5 Frigidaire/refrigerator
Frigidaire FRS26W2AW6 Frigidaire/refrigerator
Frigidaire FRS26W2AW7 Frigidaire/refrigerator
Frigidaire FRS26W2AW8 Frigidaire/refrigerator
Frigidaire FRS26W2AW9 Frigidaire/refrigerator
Frigidaire FRS26W2AWA Frigidaire/refrigerator
Frigidaire FRS26W2AWB Frigidaire/refrigerator
Frigidaire FRS26W2AWC Frigidaire/refrigerator
Frigidaire FRS26W2AWD Frigidaire/refrigerator
Frigidaire FRS26W2AWE Frigidaire/refrigerator
Frigidaire FRS26W2AWF Frigidaire/refrigerator
Frigidaire FRS26W2AWG Frigidaire/refrigerator
Frigidaire FRS26W2BSB0 Frigidaire/refrigerator
Frigidaire FRS26W2BSB2 Frigidaire/refrigerator
Frigidaire FRS26W2BSB3 Frigidaire/refrigerator
Frigidaire FRS26W2BSB5 Frigidaire/refrigerator
Frigidaire FRS26W2BSB7 Frigidaire/refrigerator
Frigidaire FRS26W2BSB9 Frigidaire/refrigerator
Frigidaire FRS26WGHD0 Frg(v1) / Refrigerator
Frigidaire FRS26WGHD2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WGHD3 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WGHW0 Frg(v2) / Refrigerator
Frigidaire FRS26WGHW2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WGHW3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WNCD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WNCD1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WNCD2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WNCD3 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WNCD4 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WNCD5 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WNCW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WNCW1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26WNCW2 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26WNCW3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WNCW4 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WNCW5 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WPCD0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26WPCD1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26WPCD2 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26WPCW0 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26WPCW1 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26WPCW2 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26WPFD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WPFW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WQHD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WQHD1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WQHD2 Frg(v1) / Refrigerator
Frigidaire FRS26WQHW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26WQHW1 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26WQHW2 Frg(v2) / Refrigerator
Frigidaire FRS26WRAD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WRAW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WRBD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WRBD1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26WRBW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WRBW1 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26WRCD0 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26WRCD1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26WRCD2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WRCD3 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WRCD4 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26WRCD5 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WRCD6 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26WRCW0 Frg(v5) / Side By Side Refrigerator
  #2 (permalink)
Old 01-07-2015, 03:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
The given model number seems to be short several digits.
Please check it.
The evaporator fan is probably controlled by the defrost board.
I cannot be 100% sure without the complete model number.
It also controls the compressor but this is a separate output so I would say that the board is bad.
The thermostat clipped to the evaporator coil controls power to the defrost heater. The defrost time is a set time usually around 30 minutes but if the frost has been removed in lets say 15 minutes the thermostat opens killing power to the heater. The cycle then continues with the heater off.
__________________
  #3 (permalink)
Old 01-07-2015, 08:52 AM
Junior Member
Default
Sorry model # is FRS26RLECSC. I removed the board last night to find it fried. Probably occurred when power came back on after a power outage. Got a new board installed and the fridge is up and running. Thanks!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer cold, Fridge warm, coils are frozen ea711 Refrigerator & Freezer Repair 0 04-13-2011 06:47 AM
fridge warm freezer cold ice on coils dypotts Refrigerator & Freezer Repair 1 08-28-2010 09:05 AM
Freezer coils ice up within 1 week =no cold in fridge wandernivy Refrigerator & Freezer Repair 0 03-11-2010 12:30 PM
fridge warm freezer cold coils icing up ron f Refrigerator & Freezer Repair 1 10-19-2009 04:53 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 05:43 AM
