johnmc98
#1 Posted : Sunday, January 4, 2015 3:57:08 PM(UTC)
johnmc98
Hello all,
I am trying to figure out a problem with my frigidaire upright freezer. Some time back we noticed the upper shelves were thawed out, but the items in the basket at floor level were still frozen solid. The compressor is running, seems to be all the time, evaporator fan does not run. Pulled cover out and checked for continuity at the defrost sensor, heater element and evap. motor and found all had it. The control does seem to work, as you can shut off then turn back on and hear the compressor start back up. Also when I first pulled the cover out of the back, the whole area directly under the evaporator coil was a block of ice all the way into the drain, like the heater had been running an extremely long time. Any help with this will be greatly appreciated.
#2 Posted : Wednesday, January 7, 2015 2:36:32 AM(UTC)
Parts for Frigidaire FFU14FC4AW0 Freezer - AppliancePartsPros.com
Here is a wiring diagram.
http://manuals.frigidaire.com/p..._pdf/StCloud/2168037.pdf
Spounds like the fan is bad.
[COLOR="Blue"]The compressor is running, seems to be all the time, evaporator fan does not run. [/COLOR]
If the compressor is on then the fan should be on as they are wired in parallel. Check for 120 volts across the fan.
If there is 120 and the fan does not run, it is toast.
[COLOR="Blue"]Pulled cover out and checked for continuity at the defrost sensor, heater element and evap. motor and found all had it.[/COLOR]
Continuity on a motor does not mean that it is OK.
[COLOR="Blue"]Also when I first pulled the cover out of the back, the whole area directly under the evaporator coil was a block of ice all the way into the drain, like the heater had been running an extremely long time.[/COLOR]
I am not sure why you feel the heater had run for a long time?
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire upright freezer temperature display acting strangely (Refrigerator & Freezer Repair)
by redroverguy 1/1/2024 11:34:30 AM(UTC)
Kenmore upright freezer cycle of warming up then chilling below zero. (Refrigerator & Freezer Repair)
by bigcheesehead 9/27/2023 9:05:10 AM(UTC)
Kenmore upright freezer model 253.280528015 keeps tripping ground fault (Refrigerator & Freezer Repair)
by Guest 8/24/2023 11:17:55 AM(UTC)
Frigidaire upright freezer model FFFH17F2QWA (Refrigerator & Freezer Repair)
by Guest 4/6/2023 11:29:17 AM(UTC)
Frigidaire Upright Freezer Misbehaving (Refrigerator & Freezer Repair)
by sun_lover 3/23/2023 12:32:46 PM(UTC)
Green Light at bottom front of Frigidaire upright freezer (Refrigerator & Freezer Repair)
by Guest 9/7/2022 10:43:50 PM(UTC)
Sears cold spot upright freezer Model #2423 (Refrigerator & Freezer Repair)
by Guest 9/1/2021 6:06:27 AM(UTC)
Whirlpool Upright freezer throwing itself into defrost mode (Refrigerator & Freezer Repair)
by Wayne O 7/26/2021 10:25:04 AM(UTC)
Frigidaire upright freezer runs for several hours then shuts off (Refrigerator & Freezer Repair)
by Guest 7/21/2021 11:32:11 AM(UTC)
Frigidaire Upright Freezer (FFH17F7H) showing wrong temperature (Refrigerator & Freezer Repair)
by Guest 7/21/2021 6:21:52 AM(UTC)
Frost/ice on only one upright freezer shelf (Refrigerator & Freezer Repair)
by whitedavidp1 4/28/2021 12:33:57 PM(UTC)
Defrost cycle-Fridgidaire mod FPUH19D7LF1 upright freezer (Dishwasher Repair)
by samv 6/23/2020 1:02:25 PM(UTC)
upright freezer frosting/icing after gasket replacement (Refrigerator & Freezer Repair)
by woakley 9/30/2019 7:09:57 AM(UTC)
GE 20DADRWH Upright Freezer (Refrigerator & Freezer Repair)
by Robo1027 3/3/2019 3:47:26 PM(UTC)
