Ok. To add to my previous problem of no water after replacing filter,but water will work without filter installed. I depressed both supply and return plungers with water on and there was pressure on both lines????in the filter housing. You can hear the filter filling up when installing. This thing worked great until I simply popped out the old and pushed in the new. Please help
