Freezer is too cold at times then not cold enough at other times. It seems that when the freezer is too cold it also freezes the line for the water dispenser. I had to replace the water tank once inside the refrigerator because it began too leak possibly from the increased back pressure. Is this due to circulating fan malfunction?
