Discuss
Water flow/pressure is low from water dispenser
 in
Refrigerator & Freezer Repair
I noticed in the past week that the water flow coming from the water dispenser of my refrigerator has been
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water flow/pressure is low from water dispenser
  #1 (permalink)
Old 12-10-2014, 07:33 PM
Junior Member
dcanderson2 is on a distinguished road
Default Water flow/pressure is low from water dispenser
Model Number: 10658146801   Brand: Kenmore   Age: 5 - 10 years
I noticed in the past week that the water flow coming from the water dispenser of my refrigerator has been decreasing. So I checked the house water pressure and it is 45 psi. Next step was to change the filter, (Filter has been installed about 2 months) after I removed the old filter I checked the water pressure from the dispenser and it was back to normal. My frig is designed so you can remove the filter and continue using it without any adapters. When I went to install the new filter, (Whirlpool #4396710) I noticed water seeping out of the top hole where the filter plugs in. I have never seen this before. What made me look was that you could here the water hissing as it was coming out. I went ahead and pushed the the new filter in and the pressure came out normal for a second or two then went back to a trickle as before but now maybe a little worse. If you wait a few seconds and check the water the pressure it is good for a second then slowly goes to a trickle. I have read where others have posted problems similar, but it appears mine is a little different with water coming out after the filter is removed. Looking for help. Thanks
Related Models
Kenmore 10658146801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658149800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658149801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658152800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658152801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658153800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658153801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658154800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658154801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658156800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658156801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658159800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658159801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658162700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658162701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658162702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658162703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658162704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658163700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658163701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658163702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658163703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658163704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658164700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658164701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658164702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658164703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658164704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658166700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658166701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658166702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658166703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658166704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658169700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658169701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658169702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658169703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658169704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658172700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658172701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658172702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658172703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658172704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658173700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658173701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658173702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658173703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658173704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658174700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658174701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658174702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658174703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658174704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658176700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658176701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658176702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658176703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658176704 SIDE BY SIDE REFRIGERATOR
Kenmore 10658179700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658179701 SIDE BY SIDE REFRIGERATOR
Kenmore 10658179702 SIDE BY SIDE REFRIGERATOR
Kenmore 10658179703 SIDE BY SIDE REFRIGERATOR
Kenmore 10658179704 SIDE BY SIDE REFRIGERATOR
Kenmore 1065821160 COLDSPOT FREEZER
Kenmore 1065821200 COLDSPOT FREEZER
Kenmore 10658212400 REFRIGERATOR
Kenmore 10658214400 REFRIGERATOR
Kenmore 10658219400 REFRIGERATOR
Kenmore 10658222700 REFRIGERATOR
Kenmore 10658224700 REFRIGERATOR
Kenmore 10658226700 REFRIGERATOR
Kenmore 10658228700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658229700 REFRIGERATOR
Kenmore 10658232700 REFRIGERATOR
Kenmore 10658234700 REFRIGERATOR
Kenmore 10658236700 REFRIGERATOR
Kenmore 10658238700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658239700 REFRIGERATOR
Kenmore 10658242890 REFRIGERATOR
Kenmore 10658242891 SIDE BY SIDE REFRIGERATOR
Kenmore 10658247890 REFRIGERATOR
Kenmore 10658247891 SIDE BY SIDE REFRIGERATOR
Kenmore 1065825120 COLDSPOT FREEZER
Kenmore 1065825160 COLDSPOT FREEZER
Kenmore 1065825200 COLDSPOT FREEZER
Kenmore 1065827120 COLDSPOT FREEZER
Kenmore 10658272800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658272801 SIDE BY SIDE REFRIGERATOR
Kenmore 10658273800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658273801 SIDE BY SIDE REFRIGERATOR
Kenmore 10658279800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658279801 SIDE BY SIDE REFRIGERATOR
Kenmore 10658282890 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658282891 SIDE BY SIDE REFRIGERATOR
Kenmore 10658282892 SIDE BY SIDE REFRIGERATOR
Kenmore 10658285890 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658285891 SIDE BY SIDE REFRIGERATOR
Kenmore 10658285892 SIDE BY SIDE REFRIGERATOR
Kenmore 10658287890 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658287891 SIDE BY SIDE REFRIGERATOR
Kenmore 10658287892 SIDE BY SIDE REFRIGERATOR
Kenmore 1065829100 MIRA-COLD FREEZER
Kenmore 10658322800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658322801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658323800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658323801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658329800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658329801 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10658422700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658424700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658426700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658429700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658432700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658434700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658436700 SIDE BY SIDE REFRIGERATOR
Kenmore 10658439700 SIDE BY SIDE REFRIGERATOR
Kenmore 1065845140 COLDSPOT DEHUMIDIFIER
Kenmore 1065845141 COLDSPOT DEHUMIDIFIER
Kenmore 1065845180 COLDSPOT DEHUMIDIFIER
Kenmore 1065845181 COLDSPOT DEHUMIDIFIER
  #2 (permalink)
Old 12-23-2014, 03:02 PM
Junior Member
Default
Fixed, I ended up replacing the water filter housing. What has happen over time was that calcium was building up on the valves internals of the filter housing. This caused the problem of leaking water when the filter was removed and caused the low flow problem. When the filter was installed, the valve was in a mid position because of the calcium buildup. This caused the reduced flow. I tried blowing air through the old housing and it helped some, but the damage was done. Hope this helps the next person. One lesson I learned was to remove the 2 screws that hold the valves in the back so you can pull the filter housing out far enough to remove the 2 lines. None of the tutorials you tube videos suggested doing this. Experience is something you get right after you need it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Low water pressure in water dispenser comenjo Refrigerator & Freezer Repair 0 11-08-2014 08:25 AM
Water Dispenser low water pressure Thiennguyen Refrigerator & Freezer Repair 0 04-10-2014 12:26 PM
Water dispenser--low pressure. Ice maker--hollow ice cubes and dispenser problem uswdyp47 Refrigerator & Freezer Repair 0 09-05-2012 11:14 PM
Water Dispenser no flow, leak and ice buildup in ice dispenser scott-optrex Refrigerator & Freezer Repair 3 05-31-2011 07:08 AM
Low water flow from dispenser racerm Refrigerator & Freezer Repair 5 05-03-2009 09:01 PM
